Ir para o conteúdo principal
Guias de dispositivos e reparo para o smartphone Huawei P30. Smartphone topo de linha da Huawei lançado em março de 2019, apresentando uma tela OLED de 6,1" e um sensor de impressão digital integrado na tela.
Microphone only recording on one side
Hey ya’ll
I've had this phone for almost 2 years now and its working quite fine.
However in the last few months the microphone started acting up and this is quite troublesome as i make a lot of phone recordings.
Whenever i now make a video or a voice recording the audio only pans to the left ear of any set of earphones/headphones i have. I've tried using different recordings apps but nothing seems to work. Anyone have an idea of what's wrong? Would be a great help :)
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Bro, in my huawei p30 pro too
When im recording vidio, the sound only can hear from left earphone, idk
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @lvdb00 ,
Does the phone work OK in loudspeaker mode i.e. can you be heard OK when on a call in this mode?
There are 2 microphones in the phone.
One is located at the bottom of the phone and usually is located behind the voice inlet hole on the bottom edge of the phone. Assuming that you can be heard OK when using the phone in the normal manner when calling a number etc this would mean that this microphone is OK.
When on a loudspeaker (hands free?) call the other microphone located at the top of the phone near the earpiece receiver is used. I don’t know your model but check if there are any holes near the receiver that may be clogged preventing the sound getting through to the microphone.
I’m thinking that to get “stereo” recordings both microphones would be utilized.
Esta resposta foi útil?
Pontuação 2
Hi, go to setting, search mono audio, switch it on.
Pontuação 1
2 comentários:
Bro, its work, thanks 😂😂😂
por
Only works for listening (speakers), not recording/microphones (at least on my phone)
por
Adicionar a sua resposta
Lester van den Berg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 2,127
