Pixel 2 stopped charging.
I went to charge my pixel and thought I seen a small shock when I plugged it in. Now it won't charge or turn on. Could this just be a battery issue or is it a bigger problem?
Esta é uma boa pergunta?
If the battery is dead that could be why it’s not turning on, the shock you seen is probably the charging port board so it would need replaced and that’s the only way to check you haven’t fried something on the motherboard
Esta resposta foi útil?
The phone was not dead, I was pluging it in because it was at 20% battery. But as soon as I seen the little shock the phone went dead and no matter what cord I used it would not charge. I tried all my cords and even tested the Cords on other phone that use the same type. I also tried my car charger and nothing. Once it went dead it has never come back on.
Before you go tear it apart its best to check the charge port it could be full of lint or other debris. You can sometimes clear it just with compressed air but if the debris is packed in tight it may require you to clear it with a pic. use a plastic or wooden pick not metal as metal can damage the outlet . Dont pry on the center as it can be broke off with enough force and then you would be in a bigger issue.
There could also be bigger issues such as a bad battery , or a bad charge port
This might help Substituição da placa-filha do Google Pixel XL
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 812
