Ir para o conteúdo principal
Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
Imagem
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
3 comentários
I am curious if you found a good solution for this?
por
@grayraver See oldturkey03's answer
por
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Do i need to connect with a parallel connection?
por
On SMove pictures it shows 7.4v battery, so it looks like we need to connect two 3.7v batteries sequentially.
But connector shows 4 wires - 2 red and 2 black. Does connector actually connects them sequentially?
por
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
Pontuação 0
Adicionar a sua resposta
Randy Northrup será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 1,465
