Ir para o conteúdo principal
A 13-inch "2-in-1" laptop with a 360-degree hinge that allows it to convert to a tablet-like form factor.
13 Perguntas Visualizar todos
Battery compatible with my device?
Hello, I wanted to confirm that the Dell WDX0R battery listed for the Inspiron 13-5368 would be compatible with the Inspiron 13-5378? The battery is completely dead, so it can be only used on AC power and I wanted to replace it.
Dell WDX0R Battery
Thanks!
Imagem de Dell WDX0R Battery
Produto
Dell WDX0R Battery
$69.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
https://www.amazon.com/LNOCCIY-WDX0R-Bat...
according to what I can find no they are slightly different but here is the correct battery
Esta resposta foi útil?
Pontuação 1
13 comentários:
Hi @stressmaster ,
In the link you posted it shows that the battery, model # WDXOR, is compatible with a Dell 13-5368 and a 13-5378.
It's the same battery model number as shown in the image for the ifixit one, so it should be the same or am I missing something?
If necessary the OP can check using this link to check for compatibility using the laptop's service tag. It is also a WDXOR battery
Cheers
por
@jayeff you will notice that that model doesn't show up in the like. I believe it is a Wh thing or a screw placement.
por
@stressmaster The wh just means it will run longer, especially if this battery has a higher Wh rating then the original. The voltage has to match or be in the supported range, but you can upgrade the Wh on a laptop battery.
por
@stressmaster
It can't be a screw placement otherwise what's the point of model numbers?
If they had different model numbers, albeit only a suffix to the model number, then fair enough, that would denote that they're different in some way.
This link also shows that a WDXOR battery is compatible with both models that the OP asked about.
por
@jayeff looks like you're right and it's compatible. Maybe ifix needs to update listing
por
Exibir mais 8 comentários
Adicionar a sua resposta
Auchhior será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 153
