Change power supply
How can I change power supply?
Esta é uma boa pergunta?
Roger Marcoux, I am not a Mac person, but a PC kind of person. So take my answer with a good amount of scepticism. It looks to me like your G3 does not use a conventional power supply. It appears that is uses a Power/Analog/Video Board that distributes all the power. You can download the iMac G3 disassembly guide from here for further information. You can also check on here for further instructions. Hope this helps, good luck.
Esta resposta foi útil?
I would include a warning about the possibility of coming across high voltage that is supplied to the CRT. A lack of care could be fatal. The CRT should be allowed to drain and then be discharged before working in this area.
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,538
