Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a 5ª geração do Apple iPad com 4G LTE, disponível com 32 ou 128 GB de armazenamento. Lançado em março de 2017. Identificado pelo número de modelo A1823. Possui tela Retina de 9,7" e processador A9 de 64 bits.
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
por Compartilhar
Adicionar a sua resposta
Chris Reader será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 370
