Ir para o conteúdo principal
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Perguntas Visualizar todos
Flashing Power LED - Not what you think...
My New Nintendo 2DS XL power LED flashes red as if the battery is about to run out, and shows the battery icon on the home screen with a single bar of power left.
The battery is not actually about to go flat though. Regardless of how much charge the battery has, the 2DS XL thinks it is about to go flat. I can play for hours with it flashing and it will be fine but I will have no idea when it might actually run out of battery, so realistically it can only be played while charging.
I can very temporarily fix the issue by letting the buttery run completely dry and then charge the battery. When I turn it on it will have a blue light and proper charge, but at some point goes back to flashing.
Would replacing the battery fix this, or is it more likely a connector or something else?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Just realized I never came back with closure.
I opened up the case and painfully removed the battery (2DS XL batteries are "not replaceable") and put it back in. That's all it took for the battery to work properly. I've been using it a bunch these past 2 years and it has behaved correctly ever since.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
@fliggle_slaps start with a new battery. It sounds like there are issues with the “Gas Gauge”. Even if the battery does not resolve it at least you have a known-well starting point should further troubleshooting be needed. New Nintendo 2DS XL Battery Replacement
Pontuação 1
Adicionar a sua resposta
Fliggle_Slaps será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 44
Duração total: 653
