Ir para o conteúdo principal
New Nintendo 2DS XL Battery Replacement
O que você precisa
  1. New Nintendo 2DS XL Battery Replacement, Back Cover Removal Preparation: passo 1, imagem 1 %32
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The microSD card
  2. New Nintendo 2DS XL Battery Replacement, Back Cover Removal: passo 2, imagem 1 %32
    • Use a tri‑point Y00 screwdriver to unscrew the four 6 mm‑long screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Battery Replacement, Case Separation: passo 3, imagem 1 %32 New Nintendo 2DS XL Battery Replacement, Case Separation: passo 3, imagem 2 %32
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Battery Replacement: passo 4, imagem 1 %32 New Nintendo 2DS XL Battery Replacement: passo 4, imagem 2 %32 New Nintendo 2DS XL Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Battery Replacement, Battery Removal: passo 5, imagem 1 %32 New Nintendo 2DS XL Battery Replacement, Battery Removal: passo 5, imagem 2 %32
    • The battery is lightly adhered to its enclosure.
    • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
Conclusão
49 outras pessoas executaram este guia.
Tim Newman
Membro desde: 09/25/17
2.012 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S18-G6, Forte Fall 2017 Membro de Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Membros
Autoria de 24 guias
16Comentários do guia
Does the 2ds xl have the same as the new 3ds xl
Royce davenport - Responder Compartilhar
no. the 2ds shares the same battery type as the Nintendo DS and the Nintendo switch pro controller.
Jason - Compartilhar
@avegaming Nintendo 3DS*, not DS
Jpeg - Compartilhar
CTR-003 Battery
stephen cheshire - Responder Compartilhar
Do I need to put a sticky pad on the new battery?
bryan sepulveda - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 58
Últimos 7 dias: 421
Últimos 30 dias: 2,006
Ao todo: 116,205
