Ir para o conteúdo principal
A primeira geração do Lexus RX300, um SUV crossover de luxo.
Location of brake module
My brake light aren't working. Have already replaced the pedal switch
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
What is the model of the vehicle i.e. RX300, RX400, RX450 etc?
Did you check that the Brake fuse (aka Stop fuse) is OK?
Here’s an image taken from the 2000 RX 300 series service manual which details how to test the brake light circuit.
Imagem
(click on image to enlarge)
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
3 comentários:
How do you replace the brake module on a 2002 Lexus RX 300
por Compartilhar
@M Haag what are you referring to as the brake module? What is wrong with yours?
por Compartilhar
My brake lights don’t work checked everything but module
por Compartilhar
@M Haag
I think that the 2002 model is the same as the 2000 model.
If so there's no "brake module" per se.
Did you test the "light failure sensor" as described in the image above?
Here are some images from the Lexus RX300 MCU15 series that shows the brake light circuit. I believe that this series covers the year range of your vehicle.
Imagem
Imagem
(click on images)
Pontuação 0
Adicionar a sua resposta
Jackie High será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 1,126
