Ir para o conteúdo principal
Modelo A1019 / disco rígido de 10 ou 20 GB / porta FireWire de tamanho normal
iPod 2nd generation Headphone jack broken
Hi - my headphone jack is broken. I took the iPod apart and the headphone jack is soldered to board. Any idea how to replace it? I found a replacement part online but dont know how to use it. My model number is M8740LL/A. Thanks
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I have the same problem, please pass on the details of the replacement headphone jack so I can order one myself- thanks!
por
Can you please post what the replacement part is? I've looked everywhere!
por
Adicionar um comentário
1 resposta
Solução escolhida
You can try and solder it yourself after you practice on some other components until you become proficient, or you could just take it to your local TV/Radio repair person and have them solder it. Remember that what makes these guys usually expensive is to dismantle and diagnose, which is time consuming. In your case, it's disassembled and should be straight forward. Also, do not forget your local High School and Colleges, check for their electronics courses, if you do not a TV repair person handy. They are almost as hard to find as parts for your iPod. ;-) Kit de habilidades eletrônicas 101 and http://www.aaroncake.net/electronics/sol... might be a good start....good luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
nbhidemisc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 971
