Ir para o conteúdo principal
The Brother HL-5240 is an office laser printer released in November 2005.
Paper Feeder picking up extra paper
The primary feeder is picking up an extra sheet of paper every time we print. Any advice? The issue could be environmental…we have two of these and both are doing this.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Devon Dillenbeck static and humidity can do this. Try some heavier and higher-quality paper and see if that changes things.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You are probably right about environment if both are doing it. Try fanning the paper before inserting into tray to insure it is not sticking together and to dissipate static.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Great Suggestion! ...I will try this.
por
Adicionar a sua resposta
Devon Dillenbeck será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 223
