Data recovery black screen.
When i turn on my laptop it turns on but the screen stays black but the caps lock blinks on and off alot. I want to know how to get my data on the laptop.
Esta é uma boa pergunta?
Hi,
What is the full model number of the laptop as shown on the information label on the bottom?
Easiest way is to remove the HDD and insert it into a caddy and then connect it to a desktop PC as a secondary drive.
There are links online that show how to connect a HDD from a dead laptop.
Is there a sequence to the Caps lock blinks? Check if there is a pause between the blinks e.g. 4 blinks - pause - 4 blinks - pause etc. This may be an error code which tells you what is wrong
@ matt tav
Here's the maintenance and service guide for the laptop. Go to p.55 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
Here's a link that explains what to do when you have the HDD
Esta resposta foi útil?
HP Pavilion dv4-2140us Entertainment Notebook PC
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 245
