Ir para o conteúdo principal
Lenovo's 1st generation convertible 2-in-1 laptop in its ThinkPad X1 line with a 14" touchscreen that pairs with included stylus pen. Released in 2016 with model number 20FQ00****
9 Perguntas Visualizar todos
new battery still shuts down when ac power is unplugged
laptop shows battery charge is at 100%. when I unplug the ac power the laptop immediately shuts down even with new ifixit battery. ive tried several different ways to reset it. looking for more suggestions.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Just to verify that the battery is OK, create a battery report to check it status.
Compare the Design Capacity value against the Full Charge Capacity value. With a good battery they should be nearly the same.
Does it do this if you reconnect the old battery again?
Esta resposta foi útil?
Pontuação 1
1 comentário:
I did a battery report. It checked out okay. The capacity values were nearly the same. But with the old battery, the computer would pop up a screen that said the battery was bad and needed to be replaced. It did the same thing to where it would shut off immediately after AC power was unplugged.
por
Adicionar a sua resposta
anthony samsel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,127
