Ir para o conteúdo principal
O Razer Blade (2018) é um notebook gamer de 15,6 polegadas lançado em maio de 2018.
Razer Blade 15 Advanced Screen Replacement
I have the Razer Blade 15 Advance with an RTX 2060. Last night my son threw a car at it an broke the screen. I see some replacement screens on amazon but they say that they are for the GTX 1060/1070 models. Will this screen work for my RTX 2060 model?
https://www.amazon.com/EM-EMAJOR-TECH-LL...
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Can you take out the screen and post a picture of the back here? To do this, go to Options>Edit on your question. Put your cursor after the last piece of text and hit enter/return on your keyboard. Select the image icon, then select Upload. After your image is finished uploading, select it. Finally, select "Submit Revision"
por
Sure I'll take it apart this weekend and send some pics.
por
Adicionar um comentário
1 resposta
Solução escolhida
I’m almost certain it will work with your current model(same screen size, same amount of pins on the connector). If you want to be sure you got the right one, I found a screen with the same model number here.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I ordered this screen like 1 hour ago after I took it apart. I really appreciate the help and confirmation on my order.
por
Adicionar a sua resposta
Anthony Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 1,205
