Ir para o conteúdo principal
Guias de reparo e manuais do usuário para o Lenovo IdeaPad 330-14AST. O Lenovo IdeaPad 330-14AST é um notebook projetado para uso casual.
Always enter into boot mode whenever I open it...
Imagem
Whenever i open my laptop it goes into boot mode and when I exit it it shows write protected and hardisk not attached but I have a hard disk in it .It is showing the above picture when I go into bios.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
When in BIOS, look through the BIOS menus and check that it shows that it has detected the HDD.
If there isn’t a HDD listed in BIOS you need to check if the HDD is connected OK. Can you hear the HDD spin up when the laptop is first started?
Here’s the hardware maintenance manual for the laptop. Go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the HDD. This will allow you to check if it is connected OK and also if you can hear or “feel” it spinning.
If the BIOS does show the HDD then perhaps the HDD boot information is missing or corrupted. Here’s a link that may help with this.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Sir pls visit that pic once.
por Compartilhar
@Satyam Singh
Try updating the BIOS from a USB flashdrive and see if that works
por Compartilhar
Esta resposta foi dada inicialmente para uma outra pergunta.
I had somethinig similar. What helped in my case was "Load BIOS defaults"...
Pontuação 0
Adicionar a sua resposta
Satyam Singh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 2,263
