My dryer has a standard plug, how do I plug it in?
My kenmore he3 dryer has a standard plug, and plastic clips to hook the wire up to the dryer? How am I supposed to plug it in? 220 outlets aren’t a standard outlet.
Esta é uma boa pergunta?
@jennpaq it won’t be a standard plug if it is a 220V dryer and if you are anywhere on the North American continent it is. Check your plug. There are things like a NEMA 6-20P that at first looks like a normal plug. Since you got it powered up there should be no more issues with the plug. You can always post pictures of the plug on here so we can see what you got. Adicionar imagens a uma pergunta já existente Let us know what the complete model number is so we can help you further
Press the Pause/Cancel button to exit diagnostics.
Check on here Kenmore-Elite-HE3-Dryer-Tech-Sheet.pdf for the tech data sheet
Esta resposta foi útil?
Good morning. It sounds like you have a gas dryer and not an electric dryer.
The other responder jayeff asked for the model number. That is most likely around the door of the dryer. That would help us to search for the information.
No, it’s a 110 dryer. I got power to come on, but it won’t come out of diagnostic mode
The full model number would really help as they're not all the same even though they start with the same series number, i.e. 110
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 105
1 comentário
Hi @jennpaq ,
What is the model number of the dryer?
por jayeff
