How would you remove these in a way that they can be reattached?
I've found no brand specific info(contacted support as well), a local repair shop told me the same thing I already knew(defect most likely under the shields, removal is time-consuming), so it's time to generalize.
Anyone here, who knows what I should be prepared to learn to work with? The phone is Asus Rog Phone 3.
My motherboard - https://ibb.co/GxCfb6Z
Screenshot of the motherboad without the shields - https://ibb.co/xC3CkG7
Esta é uma boa pergunta?
2 comentários
mannga you are way to general. It might help if you are telling us what it is that you want to reattach? What has come off? What's going on with your phone? What information are you looking for?
por oldturkey03
@oldturkey03 I need to remove the metal shields that are circled in the images, because there might be some defects to the contents under. The rest of the motherboard is not defective, these are the only places that couldn't be checked. I will need to reattach them afterwards.
Phone recognizes charger, the empty battery charging icon shows up, but the phone won't boot or charge. The chips under the plate heat up, so there might be something working there.
After a screen replacement(screen was tested before on the same phone, which was in fully working condition), I decided to swap the old, dried up thermal paste for new. I gently wiped the old one off, but since it's in such a small scale, I might've pushed a bit of it under the shields, which might be too much. I now that thermal paste is non-conductive, and I have been told that it couldn't be the cause of my issue. I did try to rinse it out with 90% isopropyl, but the plates are sealed on there pretty tightly, so I might've made a bigger mess.
por mannga
