Ir para o conteúdo principal
The Intel-powered HP Omni 10 tablet was released in December 2013 and its identification number is F4C56UA#ABA.
9 Perguntas Visualizar todos
Charging port not working
My omni10 HP charging port has spoil… How can I get the pot so that I can Change it please
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Olabode olawale the port is soldered to the motherboard. So you will have to remove the board. Follow something like this guide HP Omni 10 Battery Replacement to at least get to the motherboard. There are not a lot of guides out there yet. Once you have the board out, you will need to un-solder the old port and replace it with something like this
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Olabode olawale será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 169
