Ir para o conteúdo principal
HP Omni 10 Battery Replacement
O que você precisa
  1. HP Omni 10 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Battery Replacement: passo 2, imagem 1 %32
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Battery Replacement: passo 3, imagem 1 %32
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Battery Replacement: passo 4, imagem 1 %32 HP Omni 10 Battery Replacement: passo 4, imagem 2 %32
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Battery Replacement: passo 5, imagem 1 %32 HP Omni 10 Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Conclusão
3 outras pessoas executaram este guia.
Alex Miller
Membro desde: 10/11/16
345 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2016 Membro de USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 4,178
