How do I add ram and how much ram can I add?
want to speed up my imac g3 m5521 and how well will it operate if maxxed out?
Esta é uma boa pergunta?
Hello James Just in case your computer has the door on the bottom I am including a link to an article on upgrading early imacs. Scan down to the bottom of the article and you will see a series of pictures. Click on them one at a time and they will expand giving you a clear idea of what to do. Hope this helps you.
http://www.macworld.com/article/2496/200...
Link to a guide showing how much memory Macs can use.
http://www.everymac.com/systems/by_capab...
Maxed out it will run better but not as well as a new iMac.
Esta resposta foi útil?
Maximum RAM: 1.0 GB (2*512MB)
Type of RAM Slots : 2 - PC-100 3.3V 168-pin SDRAM
This is for a M4984 -- not a M5521 and may not be accurate for his computer.
The M4984 has a max ram of 384 MB--the M5521 has a max of 1 GB.
yes I know, but I though that it was almost similar as the change in these iMacs were only hardware updates.
James follow rj link
- "almost similar", just doesn't cut it with computers
Imac model M5521. Can I install a wireless connection, this has only dialup capability? Same question re DVD drive, can one be installed? Is there a source for these items?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 50
Ao todo: 5,762
