Ir para o conteúdo principal
Really screwed the pooch here...
[flag|no area]
[flag|stub]
Imagem
Imagem
Long story short, one ear cup became…detatched…from the headphone wiring (and also the pads on the PCB) before note was taken of original placement. Now if the pads on the pcbs were the same we wouldnt be having this conversation. The original wires(from top to bottom of yellow PCB) are red/blue/white/red-gold/green.
Imagem
There are no inner wires in any of them, just the cloth strings for strength. The markings on the pads (blue pcb) read(from top to bottom:): Batt/TS/GND/speaker-/speaker+.
Yellow pcb reads Batt/what im pretty sure reads 'mic'/GND/
Amp_r_n/amp_r_p
Now intitially i soldered it together as shown here
Imagem
But it left a horrible buzz in the left ear and no mic. Any
Esta é uma boa pergunta?
Pontuação 0
1 comentário
where is the battery located in hyper x cloud orbit s wired headset?
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
I am pretty confident that the ‘Amp_r_n’ corresponds to ‘Speaker -’ and ‘amp_r_p’ to ‘Speaker +’.
If you have a multi-meter you can check the jack inlet and the last two rings should have continuity with the ‘AMP-R-N’ and ‘AMP-R-P’
All the other terminals is pretty much the same but they labelled them slightly different. I would check is the cable itself is good as due to rupture it can be broken inside the insulation and that is why you get interference in the ear and no mic.
I would get a brand new 4 core wire if I were you to eliminate this issue. Get 4 core shielded so the mic has the least interference possible.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you...
por Compartilhar
por Compartilhar
Adicionar a sua resposta
agnawn uh mous será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 39
Ao todo: 1,537
