Ir para o conteúdo principal
A terceira geração do Toyota Camry em todos os mercados fora do Japão. O período de 1991-1996 também foi chamado de série XV10 dos veículos Camry.
How to change key ignition switch
how to change key ignition switch
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Check the attached image, it will give you a breakdown as to where the parts are that you need to look at. I could rewrite the instructions but you may benefit from the excerpt of the manual.
Update
Seems like my images disappeared :-) Here is the description:
Disconnect the negative battery cable. If equipped with an air bag, wait at least 90 seconds before working on the vehicle.
CAUTION
Some models covered by this guidemay be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Chassis Electrical .
Remove the lower steering column cover. Unfasten the ignition switch connector under the instrument panel.
Remove the screws which secure the upper and lower halves of the steering column cover.
Turn the lock cylinder to the ACC position with the ignition key.
Push the lock cylinder stop in with a small, round object (cotter pin, punch, etc.).
On some vehicles, it may be necessary to remove the steering wheel and combination switch first.
Withdraw the lock cylinder from the lock housing while depressing the stop tab.
To remove the ignition switch, unfasten its securing screws and withdraw the switch from the lock housing.
To install:
Align the locking cam with the hole in the ignition switch and insert the switch into the lock housing.
Secure the switch with its screw(s).
Make sure both the lock cylinder and column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
Install the steering column covers.
Connect the ignition switch wiring.
Connect the negative battery cable. from here I also suggest to check this site and look for a posting by "Fluffy", it has some really good images that will show you how to do it. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I have same problem with my 95 camry
I baught a new ignition switch and a new ignition cylinder install it turn on the key every thing works except my steering wheel locked up while the ignition is ON!
Any one got any idea whats goin on or the issue is????
por
Adicionar a sua resposta
antweezie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 56
Ao todo: 32,254
