Ir para o conteúdo principal
O sucessor espiritual do Chromebook Pixel, o Google Pixelbook foi apresentado no evento Made by Google de 2017 e disponibilizado em 31 de outubro de 2017. Número do modelo: C0A.
Cannot boot. Screen stays black.
This is a Google Pixelbook (i5, 8 GB RAM, 128GB) bought in 2018 and out of warranty.
Last Sunday, after a software update, pixelbook rebooted andafter a while the screen turned black and since then I haven’t been able to boot it up.
When I plug the charger, led is solid green. But if I try a boot, a hard reset, or anythin else, nothing happens (except at the led level there is some activity)
I have a case opened at google support but because this is out of warranty, agent was pessimistic that they can do anything.
Here it what I have already tested:
  • standard boot but pushing power button: nothing
  • hardware reset - Holding refresh and pressing power
  • recovery mode - Holding Refresh and Escape and pressing power
  • another one - Connect the charger to the Chrome OS device. Hold the side power button + Refresh key  and remove the power adapter as they keep holding on those buttons. Wait for 1 minute. Press the side power button to test the device. Connect the power adapter and monitor the LED color. Device should try to turn on and LED should blink or have solid color.
Nothing has helped so I guess there is an hardware issue. Do you think it could be the motherboard to be replaced ? I am tempted to try to follow - Google Pixelbook Motherboard Replacement
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi There,
Another thing you can try yourself is to check if the problem is not just a loose component, you’ll need to open up some/all of the panels though.
First thing to try is to remove and re-seat the “easy to get to” components like the RAM and SSD/HDD etc.
Also take out the main battery whilst testing, it should be able to start up with the AC adapter alone.
A bit more advanced but do-able check is to take the CPU off and re-seat it. but for this you’ll need to get some new thermal compound and you’ll need to remove the old compound with some q-tips and rubbing alcohol from the heatsink and CPU before assembling back together.
If it still doesn’t work then the next step is a complete disassembly and testing all components unfortunately, for this it’ll be best to take it in to a repair shop that has the proper spares / testing equipment on hand.
Esta resposta foi útil?
Pontuação 1
Did you ever manage to get the issue resolved?
I've got a Pixelbook C0A here that's also playing dead. Same symptoms as yours, the only difference is, Esc+Refresh and Power Button launches recovery mode ok.
I've created and tried 3 difference recovery images v15662.64.0, v15662.35.0 (Beta) and v15437.84.0.
The recovery completes ok, tells me to remove the USB to restart automatically. When I remove the USB, the screen goes blank and it doesn't reboot/boot. It goes back to playing dead again.
The battery is definitely charging ok as the charging LED went from white to green and I can power up in recovery mode on just battery.
Makes me think Google pushed out a dodgy OS update rather than there being any kind of hardware issue.
Imagem
Pontuação 0
2 comentários:
I have the same problem today on my PixelBook. I am going to try to at least get into the Recovery mode.
por Compartilhar
ok Guillaume RAMELET I will say you installed a update that screwed up your laptop the best bet if you have another device go to cros.tech at (https://share.google/dUBouDJzrzrG4Okh6) and install the orig of CHROMEOS from the factory
steps
1. type pixelbook or codename eve
2.click the dedicated pixelbook option to find main page
3. choose the latest version do stable
4. after download go to chrome web store at (https://chromewebstore.google.com/)
and search Chromebook recovery utility and install the extension then click at the top that look like a puzzle piece for chrome and for microsoft edge click what looks to be a puzzle piece and choose Chromebook recovery utility then choose the settings logo top right corner and click local image then choose your CHROMEOS file and confirm the steps it says
5. after flash to your USB drive and plug into your pixelbook and hold esc + refresh + power and follow the steps to install os
NOTE if it does not work your bios chip is screwed motherboard replacement needed
por Compartilhar
Adicionar a sua resposta
Guillaume RAMELET será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 77
Ao todo: 4,028
