Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
only says charging please wait
ipod says charging please wait tried resetting no joy
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It is possible that you may need a new battery. There are some issues with the charging circuit on that model iPod, but start with cleaning your dock connector. Use a small toothpick and CAREFULLY remove all debris from it. Check for bend and corroded or otherwise damaged pins. Check your USB cord and make sure that it is in good working condition. If nothing externally fixes it, use this guide to replace your battery. Make sure that the battery cable is deep enough inserted in the connector. Be careful when you move the clip that holds the cable to the connector up. It has a tendency of breaking of the logic board. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
john battle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 516
