Ir para o conteúdo principal
Informações de reparo e guias para a atualização menor do MacBook Air de finais de 2018, com o mesmo número de modelo (A1932) e número EMC (3184). Este modelo possui uma tela True Tone e uma bateria ligeiramente revisada.
Left hand speaker muffled and staticy
Okay, my MacBook Air’s left-hand speaker is weird. It very very muffled and full static when compared to the right.
I thought it could be water damage and decided to replace it. I did that myself and it all went well and then went to check and no change on that speaker. It was the same as before not even a single change or improvement.
I ran Mac diagnostics, nothing came up. I also reset NVRAM/PRAM as someone had suggestion that might help. Still nothing. I’m at a total loss of what to do.
Also, I am 100% sure when I got it first it was working fine.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
What do you hear when you plug in a good set of headphones in via the headphone jack? Use the balance control to bias which headphone is playing. Do you hear it with the headphones?
If you do then the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard or MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable to the logic board is the issue. If its clean on both sides, then the logic board speaker cable connector has a problem.
Review this guide: Substituição da placa de áudio do MacBook Air 13” Retina Display final de 2018
Imagem de Replace a torn or damaged cable connecting the logic board to the audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.
Produto
$19.99
Imagem de Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.
Produto
$59.99
Esta resposta foi útil?
Pontuação 0
5 comentários:
Earphones have no problem with this. Only occurs when I use the in built speaker,
por
Look at the logic board for corrosion.
por
@danj I am pretty sure there was none since I did open up when replacing the speaking thinking that was the issue, and saw nothing much there in terms of it looking diffrent.
por
I think you'll need to bring your system into someone who has the skills to diagnose your issue. There is a limit on what I can offer for help.
por
@danj Thank you. Just wanted to exhaust all options before I did that in case it's something I can fix on my own. Really appreciate you taking you time to try and help me.
por
I had the same problem with 2 Macs, the solution was to clean the grille with a dry/clean toothbrush. The issue was that the micro-holes were blocked, which can be confirmed by passing light through them.
I could diagnose the problem by connecting the speaker without installing it, I leave it carefully hanging and it sound really loud.
I attach a photo of the blocked micro-holes.
Imagem
Pontuação 0
2 comentários:
@oliversi - To many bread crumbs! 😆
por
it acted more like a cheese grater :)
por
Adicionar a sua resposta
SeanErik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 26
Ao todo: 777
