How do I fix this screen?
Esta é uma boa pergunta?
Hi,
The screen is cracked and will need to be replaced as it cannot be repaired.
(click on image to enlarge for better viewing)
Use the link in the answer above to view the replacement procedure.
Replacement screens are available online. Just search for XE550C22 LCD screen to get results for suppliers that suit you best.
Esta resposta foi útil?
Check that the screen cable is correctly connected.
This video will show you how to take it apart.
https://www.youtube.com/watch?v=Spriegms...
This video will show you how to replace the screen but check the cable first. If it is not the cable that is the problem you will have to replace the screen.
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 348
