Ir para o conteúdo principal
Ajuda para reparo e resolução de problemas para o modelo E1-571 de notebooks Acer Aspire.
Laptop Processor Overheating Issue
I am using Acer Aspire E1-571G, i5 with 1TB HDD and *GB RAM.
Now I am facing the processor heating issue every time I used my laptop. I can’t even touch the side of my laptop as it burns.
Can someone suggest to me any solution to this issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @tinamathew
When the laptop is on, can you feel the hot air coming out of the vent or hear if the fan is operating? If not then there may be a problem with the laptop’s fan.
If the fan is operating then most probably it needs to be cleaned of any dust build up and the thermal paste on the CPU needs to be removed and replaced as it will have dried out, therefore the heat transfer from the CPU will be reduced and it will operate hotter.
Here’s a link to the ifixit Substituição da pasta térmica e limpeza do dissipador do Acer Aspire E1-571 guide that will help
If the fan is not operating it may have to be replaced. Replacement fans are available online. Just search for Acer E1-571G Cooling fan to get results for suppliers that suit you best. See above for how to access the fan so that it can be replaced.
If doing this yourself seems too daunting, contact a reputable, professional laptop repair service and ask for a quote
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Tina Mathew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 633
