Ir para o conteúdo principal
Modelo A1013, A1052, A1085 ou A1107 / Resolução de tela de 1440x900
Why is the boot screen blank?
So I’ve worked on several Macs over the years and I’ve never seen this before and can’t figure it out. I have a 17” PB 1.67. It works fine, but there is no boot screen or chime. It’s blank like what you would see when you have a non flashed graphics card in your Mac Pro. I’ve done all the normal resets and key combinations. I’ve even booted into open firmware and did the reset-all command which I only know worked because the Mac rebooted. Any thoughts? Something I can key into the terminal to bring back the Apple logo? I’ve erased and re-installed OS X as well. Anyone else seen or fixed this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Your facing the dreaded dead PRAM battery issue!
Follow this guide to get to it Substituição da bateria PRAM e da placa USB do PowerBook G4 Aluminum 17" 1-1,67 GHz which is located under the optical drive.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Dan, I will check that PRAM battery. Thanks! I probably wouldn’t have thought of that since it held the time and date with the main battery out and it’s the only thing I haven’t done.
por
Have you checked the battery? Or there is something wrong with some certain apps.
This page may be helpful: https://www.minitool.com/data-recovery/f...
Pontuação 0
Adicionar a sua resposta
brandonbanfield será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 404
