Ir para o conteúdo principal
Tablet Android RCA, identificado pelo número de modelo RCA RCT6303W87.
tablet wont start dead
tablet wont start, charge, or go into recovery mode. what can I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Did you try using a different known working, compatible charger or perhaps connecting the tablet’s micro USB port to a computer to see if it charges at all, you didn’t say?
Imagem
Did you try pressing the recessed reset button for 5-10 seconds with a straightened out paperclip and then checked if it worked OK?
Imagem
If you have tried all the above and still no good, then the tablet will need to be opened and inspected further to determine what the problem is.
Here’s the ifixit RCA RCT6303W87 guides that will help you to open the tablet.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Paul Lessary será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 322
