How do I replace the screen?
Dropped my laptop. Nothing on screen.
Took it apart but unsure how to remove lcd from the casing and hinges.
Esta é uma boa pergunta?
Hi,
Here’s a link to the hardware maintenance manual for the laptop taken from this webpage.
Go to the bottom of p.93 to view the necessary pre-requisite steps and then the procedure to remove the Keyboard bezel assembly, LCD unit and K-lock bracket
Here’s a link to find all the available LCD panel part numbers for the laptop. Click on Select Commodity > LCD Assemblies (6) to find all the LCD panel part numbers.
Once you have found the part number appropriate to your particular model variant, search online using the part number only in the search box of your browser, to get results for suppliers that suit you.
Usually the part number is located on the back of the LCD panel somewhere if if you wish to verify that you’re ordering the correct part for your particular model variant.
Esta resposta foi útil?
I have the 20FY version
I've amended the answer to suit your particular model variant.
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 35
Ao todo: 423
