Ir para o conteúdo principal
Fone de ouvido Bluetooth supra-auricular com alto-falantes de 40 mm e bateria de 610 mAh. Lançado em 2014.
speaker and battery cable replacement
Hi, my headphones stopped turning on, after searchin i found it's because cable conecting main board with battery and speaker is broken and connected battery positive with speaker. I need help with tear down, i dont know ho to open plastic slider.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @jonasskuhrovec
I don't see any other options but unscrewing that golden bolt. Have you tried it?
por
Adicionar um comentário
1 resposta
You can disassemble the earpieces. These consist of screws and plastic tabs. You already did (most of) that.
I don’t know a way to open the headband in case you need to replace that cable.
You can try to push or pull new wires through.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jonáš Skuhrovec será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 247
