Ir para o conteúdo principal
Informações de reparo e manutenção para a secadora de roupas LG TrueSteam. Números de modelo DLEX3570V, WM3670HRA e DLEX3570W para as cores grafite, vermelho e branco, respectivamente.
CL error code L G front load dryer
CL code stays on. Stands for child lock but my model does not have a button on the panel
Esta é uma boa pergunta?
Pontuação 0
2 comentários
My model number is dlex3700v
por Compartilhar
The clean filter light is on but the code cl is showing
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @coachvic,
What is the model number of the dryer?
If it is a DLEX3570V or DLEX3570W then press and hold the Easy Iron button for 3 seconds to either lock or unlock the controls.
If it is a WM3670HRA then press and hold the Pre Wash child lock button for 3 seconds
Esta resposta foi útil?
Pontuação 1
Hi @shawn03 ,
Activating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. The Control Lock icon will be shown in the display and all controls will be disabled except the Power button.
Deactivating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. Once set, Control Lock remains active until it is manually deactivated. Control Lock must be turned off to run another cycle.
Clean Filter Reminder:
The display will show Clean Filter when the dryer is turned on as a reminder to clean the filter. It turns off
when the Start/Pause button is pressed..
Pontuação 1
1 comentário:
Thank you for your two suggestions on how to turn off the CL feature on my
LG dryer. I was just about ready to pull out, what little hair that I have left.
por Compartilhar
Adicionar a sua resposta
Victor Turselli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 13,568
