Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
camshaft and crankshaft sensor locason
where r thay at on the car
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
peoplesmickey Its a bit lengthy to explain and I thought it might be easier if I let you download the Engine, Mechanical part of the manual from here. I attached a few images from the manual for your immediate use. It's number 16 in the last image ;-) Hope this helps. BTW, wondering what you are up to that you need the location for both of them ;-) Good Luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
peoplesmickey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,082
