Ir para o conteúdo principal
Aprenda sobre as habilidades que você pode precisar para trabalhar no seu dispositivo.
Which iFixit Tool-set? What alternative?
Subject: Which iFixit Tool-set? What alternative?
I recently tried to replace my Mac mini 2014 HDD to an SSD…. the problem was that I did not have a Torx 5 bit…. I thought I would invest in a somewhat comprehensive set like the Pro Tech Toolkit or Manta kit…. I guess one downside is that the bit swap concept is more bulky and more cumbersome than dedicated tools for each bit… I think I like the case for the Pro Tech better…. I think Manta as some longer bits that are useful….. Also, I wonder if there is a reputable alternative to the iFixit Chinese tools…. any thoughts?
Oh, I just broke the screen on my iPhone 6s….. so I might need some tools for that.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Here’s a kit to use for most repairs including the iPhone 6
Pro Tech Toolkit
https://amzn.to/37ow346
Imagem de The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.
Produto
Pro Tech Toolkit
$79.95
Esta resposta foi útil?
Pontuação 4
Each guide offers a listing of the needed tools for the given task. Review them to help understand what you’ll need.
Someone who is a weekend fixer will likely find the Pro Tech Toolkit is a good choice as it will cover a good 90% of what you’ll need for small device repairs.
A person who focuses on fixing MacBook system will often get discreet handle drivers as they are constantly using the same tool over and over again.
I personally have both the iFixit Pro Tech Toolkit so when I travel I have what I need. When I’m home I often use my fixed handle drivers similar to the iFixit Marlin Screwdriver Set - 15 Precision Screwdrivers
Your use case can be different from me! So you need to figure it out what works for you.
Produto
Pro Tech Toolkit
$79.95
Imagem de Phillips, Torx, Torx Security, iPhone Standoff, Tri-point, Pentalobe, and Flathead screwdrivers packed inside a fabric tool roll for compact storage.
Produto
$54.95
Pontuação 3
Adicionar a sua resposta
Mac Fun será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 5,339
