Ir para o conteúdo principal
The Brother MFC-440CN is an all-in-one color inkjet printer with a photo bypass tray first introduced in 2001.
unable to change 51
How do i fix unable to change 51 on MFC 440cn
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Do you mean an unable to print error 51?
Here’s a link that may be of some help.
I realize that it is not the same model printer but it still may be worth checking in your model as usually manufacturers don’t change their error codes that often so the error code usually means the same fault symptom but it may not have to be the same problem that caused it to happen
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
michelle gallacher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 868
