Ir para o conteúdo principal
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
20 Perguntas Visualizar todos
How do I get this working
my dell isn’t starting up i think it is the battery that doesn’t make it start
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @xxthenottakenxx ,
Does it start with the charger connected to it, you didn't say?
What lights are showing when the charger is connected or when you try to start it and are they flashing or steady?
por
Adicionar um comentário
1 resposta
If you doubt it’s the battery interfered the computer's startup process. Try removing the battery to run the laptop from just the AC power. If it works, you may have a defective battery that needs replacing.
If nothing fixed the problem, this indicates that the problem may be on other components of the laptop, at least you can do some basic troublshooting.
https://www.minitool.com/backup-tips/del...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
The not taken será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 135
