Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
20 Perguntas Visualizar todos
Mac Mini shut down suddenly when in use, failed to power up afterward
I tried changing power cable, disconnecting all peripherals, even reset system management controller (leave the power cable unplugged for > 15sec) etc, none worked. So I brought it to repair store, but they can’t be sure if it is the embedded power supply or the motherboard and insist non-refundable diagnostic payment to find out.
My question: Is there a way for me to identify what goes wrong, before deciding my next move? Where it’s me fixing it myself or sending to repair center.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Didn't realize this is posted outside of Mac Mini Late 2012 section, so that's my MaC Mini model.
por
Adicionar um comentário
1 resposta
@woooinred schematics and wiring diagrams are not available for the Mac Mini. This will make the repair of the logic board a challenge. You do want to go ahead and at least measure the voltages on the power supply. Make sure that you have 12V on all the power rails. Also, make sure that your SDRAM modules are properly seated and remove the coin PRAM battery for a minute to reset the board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
BW Tay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 48
