spilled tea on my iPod, what to do
spilled tea on my ipod, how can i get it to play? all i get is a black screen.
Esta é uma boa pergunta?
awaesaeh, the first thing I suggest is that you turn it off, do not try to turn it on again, and follow this guide After you do that, replace the battery and reevaluate. You can use the step-by-step guides below the picture of the device, to disassemble. Rice will only work to absorb some of the liquid, but will not clean anything and will not prevent corrosion. If you do not clean the logic board etc, you might end up with issues like corrosion or battery failure later on.Good Luck and let us know.
Esta resposta foi útil?
try putting the ipod in a bad with rice and leave it for a few days. if that doesnt work, the board is probably toast.
I left my ipod in my Mini ash tray with a open sun roof and found it under water after a rain storm.
I did not turn it on and put it in the oven at 150 degrees for about ten minutes, and then turned the oven off.
The ipod stayed in the oven overnight with the oven light on and in the morning the ipod worked fine.
Never turn on any shorted electronic devices.
place into a bag with rice. I am too chicken to even try the oven trick you mentioned.
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 884
1 comentário
Is it a Classic iPod?
por oldturkey03
