Ir para o conteúdo principal
iPad Air Wi-Fi + Cellular, modelo nº A1475. Disponível em cinza-espacial ou prateado, com configurações de 16/32/64/128 GB.
PMIC Replaced - Missing voltages
I have an iPad Air (1st gen) which I have replaced the PMIC. The reason for that is because the iPad charges only when it was switched off.
I have lifted the following pads during removal of the PMIC:
  • B17
  • B16
  • B15
  • C16
Dont know If this is the cause of the problems below:
  • No backlight (filters are good)
  • Missing voltage on PP3V0_SPARE1
  • Missing voltage on PP3V0_S2R_SENSOR
  • Missing voltage on PP3V3_ACC
  • No Heat on the board, and I can see apple logo on screen without backlight looping.
Anyone can point me in the right direction or explaining those missing voltage lines could be a BIG help understanding the situation.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello Peter,
too high temp and flow you use for taking off a glue and a ic. It seems like cpu overheated. Have you stencil for reballing?
Esta resposta foi útil?
Pontuação 0
6 comentários:
Yes! I have used a brand new PMIC already reballed.
Also I have measured around all Caps with Multimeter Diod mode wich resulted NO short on the board.
por
Or you suggest I should reball the CPU???
por
this is dependent to board measurement. But it looks like. I would measure RAM and NAND beforehand but it looks like yes, I would do a CPU reballing.
por
sometimes, problem is in technical's hand work. Are you sure IC is sitting down correctly?
por
A smudged the corners and it seems ok....
por
Exibir mais 1 comentário
Adicionar a sua resposta
Peter Hupuczi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 940
