Ir para o conteúdo principal
O smartphone Android Sony Xperia Z5 foi lançado em outubro de 2015. O Sony Xperia Z5 possui uma tela de 5,2 polegadas com 1080 x 1920 pixels, equipado com um processador Qualcomm Snapdragon 810, 3 GB de RAM e uma câmera traseira de 23 MP.
screen became almost black
Hi Everyone,
Suddenly, I noticed that the phone’s screen became very dark. I needed to put the phone near by a bulb light to be able to see what is on the screen as this made the phone increase the light of the screen. At the same time the phone was very hot although it was not charging (not connected to a charger). I tried to reset the phone however, I noticed that the phone is heating more so I opened the phones cover and disconnected the phone’s battery. I waited few minutes until the phone cooled down then I connected the battery. at this point something started to burn inside the phone. some smoke came from under the metal plate where the red arrow is pointing to in the uploaded photo.
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
I believe there is a burn mark on the back of the removed little cover. It can be seen on the second and third images.
Does anyone know what I need to do to repair the phone?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
M Hassan you will have to remove the EMI shield to properly identify which component has failed. As you can see there are many so unless you remove it, we cannot assist you any further.
Imagem
Update (10/26/2020)
Still trying to find the eplist for this phone. Typical Sony since they no longer have schematics at all. It may take a while. Part s are identified by reference designator
Imagem
Esta resposta foi útil?
Pontuação 0
3 comentários:
oldturkey03 - I have added more photos. Could you please check my post (question) again?
Thanks
por
Sorry, What do you mean by eplist?
Also could you please tell me how to find the parts that you mentioned on the photo?
Thanks
por
M Hassan partslist for the circuit board. That way we can determine what values the capacitor and coil are supposed to be. A few years ago Sony stopped using schematic in their service manuals etc. so it is hard to come by via the usual sources. Still working on it but it is not going to be a fast fix :-)
por
Adicionar a sua resposta
M Hassan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 467
