Ir para o conteúdo principal
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Perguntas Visualizar todos
broke the "small antenna" during battery change procedure
During the battery change procedure, which went well for the most part, I broke the “small antenna cable” identified in section 17. Didn’t notice until reassembly. Since it is not the GPS nor the WI-FI antenna, I’m unclear exactly what I will find inoperative once I finish. Is a replacement available? (I was confused by the difference in picture between the Wi-Fi model and mine. Oh well.)
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I’ve never used the Cellular capabilities of the mini 2, so will I miss anything if I do nothing? Will the mini constantly remind me that the antenna is broken? Note: I bought the cellular version to get the improved GPS capabilities.
I’m off now to get some 90% isopropyl to clean the gunk left behind from the glue.
por
I don't believe so.
por
Adicionar um comentário
1 resposta
Solução escolhida
It is the Right Cellular Antenna. With a damaged antenna, you will have less (or no) cellular sugnal.
Imagem de iPad mini & mini 2 Right Cellular Antenna
Produto
$9.99
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Leon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 8
Duração total: 67
