Ir para o conteúdo principal
Released in 2015, the ASUS X540s is a 15.6-inch laptop that comes with an onboard graphics processing system capable of outputting HDMI video.
18 Perguntas Visualizar todos
Notebook not turning on, after water dmg
Notebook Asus X543BA
Hi,
First sorry for my english but i need some help…
I just got notebook from my friend he told me that on notebook got water split. It wanst much and becouse of it he just wipe the water from it and continue using it.. after some time the notebook not turning on… i just open it and i cant see any water damage so i just check keyboard wire and saw a damage on it … i just get new one and try to use it.. but still not working…
i just dont have more tips what can it be
i tried unconect battery and turn it on without it but dont works when i connect it to adapter the led control on motherboard turns on but that all.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Soak the board in 91-99% IPA and pray that it isn’t in need of a new motherboard. Your friend may have signed this machines death certificate by not cleaning it. Seeing as it no longer works and you do not know, assume it is acidic and clean accordingly. You’ll also need a new palmrest if that keyboard is plastic welded in - if not, reference the keyboard P/N.
However, I will tell you this: Yank that hard drive if it has issues booting after cleaning the motherboard. A lot of the time, these Asus laptops do not like to boot if the drive has issues, and Toshiba drives like to fail within 1-2 years, or 2-3 with light usage; you do not know how heavily that drive was used unless you can check the POH with a tool that polls the SMART data. If that doesn’t work, you can always try to remove the CMOS battery but once you get that low with water damage the device is generally done for.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
marian.macejka.majsam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 163
