Microphones not working as they should
Hello!
I’ve had some issues with my iPhone 8 for quite a while. The microphones doesn’t work in voice memo, not in facetime and not when using speaker when calling. It works fine when doing “normal” calls and when recording with the camera both front and back
Any ideas why it doesn’t work as it should? bad ic hip?
Esta é uma boa pergunta?
1 comentário
I have the same issue with mine - the microphone works fine with Siri, Front and Rear facing video, but doesn’t work in calls on both speaker and earpiece, FaceTime & voice memos records a flat line and plays a cracking sound. I am thinking it is the bottom microphone that isn’t working, and am hoping it is not logic board.
As for history; the screen and back are cracked (bought it like this) particularly near the dock section on the back. However, everything else works fine (as far as I can tell) and I opened the phone up and all water damage indicators are white and the phone is mostly clean with little dust.
Have you found a solution yet? I have ordered a new replacement housing with parts so it comes with a new dock connector and mic so I will see if that works!
por TmG
