Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
Shall I replace the AC fan motor, or is it possbile to repair?
Hi,
I have a Hotpoint washer/dryer machine, and a shaded pole AC fan motor (see here) in it, which “works” very strange. If I connect it directly to the 230 V power network it runs very slowly, sometimes even stops, then start to spin again, and so on (no any load on the motor of course). But I can turn the motor with my finger easily.
I made a little video, where you can see the rotation stops at 00:04, then restart.
Do you think the repair of the motor is possible to repair, or buy a new one?
Thanks a lot if you can help me :-)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Csaba Katona  could be caused by bad windings. Since we do not know the motor we can’t tell you what the resistance across the windings should be etc. I would opt for a new motor
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for your help!
por
I bought a new motor, which is running almost without any friction. So the motor was definetly fault. I replaced it, since then the machine works perfectly.
Pontuação 0
Adicionar a sua resposta
Csaba Katona será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 123
