Ir para o conteúdo principal
O BlackBerry Priv é o primeiro smartphone da fabricante canadense a rodar o sistema operacional Android, combinando segurança e bom desempenho.
Screen touch working issue
My screen is broken with only a horizontal line in between while whole of the screen is working but the only problem that i face is that it works occasionally sometimes it suddenly starts taking touches and sometimes it will stop taking touch for days... How to reslove this problem is there any connections inside that i should check for?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You will have to open the phone and check that the display assembly LCD screen and touchscreen cable connection to the systemboard is secure.
If it is, then as a DIY repair all you can do is to temporarily replace the display assembly and check if the problem is still there or not. If it is still there then it is in the systemboard
Here’s a video that shows how to replace the display assembly in your phone.
Replacement display assemblies are available online. Just search for Blackberry PRIV LCD display touchscreen assembly to find suppliers that suit you
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
skuttam24x7 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 495
