Ir para o conteúdo principal
Esta página mostra guias de reparo, dicas e truques para o Huawei Honor 9, lançado em junho de 2017.
fingerprint button doesnt wwork after battery replace
Hello i replace my hono 9 battery like the guide on this topic
Substituição da bateria do Huawei Honor 9
everything are good after i turned on my phone and battery works fine.
but the fingerprint button doesnt work. its completed dead.
thanks in advance
Imagem
i reopened the phone and did the same like battery replace.
i saw a small scratch as you can see in picture in the black flex cable.
do you think that is the reason home button doesnt work?
should i try to replace it? and where can i find a guide for it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
borbou-13-  double check your work. Check the ribbon cables that are routed underneath the battery. Make sure those are all still properly connected. Inspect the ribbon cables carefully for any tears. There is really no other reason as for why the “fingerprint button” won’t work any longer.
Esta resposta foi útil?
Pontuação 3
2 comentários:
i reopened the phone and did the same steps as battery replace.
check the edited post to see the picture of the cable. you think i need to change it? and is there any guide for it?
thanks
por
I would since it is possible that this is the cause for it. there is no specific guide for that flex so you will have to find the best way using a variation of all of these Huawei Honor 9
por
How was your fix, did you managed to get this working again?
Pontuação 0
1 comentário:
i have already ordered the flex wire and waiting the delivery.
por
Adicionar a sua resposta
borbou-13- será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 724
