Ir para o conteúdo principal
Guias de reparo e suporte para tablets fabricados pela Polaroid.
How to reset lost PW
I can't log in to my Polaroid PMID910, forgot my PIN.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
cuppa_woman you will have to do a Factory Reset to possibly recover your tablet. Remember that this erases all your data on the tablet.
Press the Power button for 2-3 seconds and select Power Off/ Turn Off. Then press and hold Home and Power buttons at the same time for 10-15 seconds.
You should now see the Recovery menu
Use the Volume Down button to scroll to Wipe data / Factory Reset. Press Power button to select.
Next use the Volume Down button again and select Yes - delete data option. Press Power button to reset.
Once the reset is done select Reboot system now and press Power button to reboot.
This should have reset your tablet to a point where you can set it up again and use it like a new tablet.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
cuppa_woman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 631
