Ir para o conteúdo principal
O ventilador de mesa VLT 1000 possui quatro pás com um diâmetro de 30 cm. Ele é fabricado em aço inoxidável e tem 3 velocidades ajustáveis.
Fan speed slow initially
I have a tower fan which initially runs on low speed and after 20-30 min the speed becomes normal. What could be the reason and how to fix the issue?
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Hi,
Does it run on low speed even if a higher speed setting is selected when starting?
Do the fan blades rotate easily and smoothly if you spin them by hand? (disconnect the power from the fan before you try this)
por Compartilhar
Its at first two speed. At third (highest) speed, it functions well. Yes, the blades rotate easily and smoothly if I spin by hand.
por Compartilhar
Can you run the fan at highest speed first for 2-3 minutes then switch to low speed? Tell me if that works or not :)
por Compartilhar
Bahut slow slow chal raha hai
=== Update (08/29/23) ===
Bahut slow slow chal raha hai friend
por Compartilhar
Fan slow problom
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
@ sachin gupta
What is the make and model number of the fan as you have selected a desktop fan as the device and not a "tower fan"?
If the fan is no longer under warranty, you may have to open the fan and access the control board where the speed buttons are connected to and check the components. Usually with speed controls for fans, the switches connect or disconnect capacitors into the fan's motor circuit to increase / decrease the amount of current flowing to the motor so that it runs faster or slower.
If you see any problems or if you're not quite sure, post some images back here.
Here's how to do this Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 2
sachin gupta besides the great suggestions given by @jayeff it is also possible that your fan motor is most likely starting to gum up. I suggest you tear it down right to the motor teh clean the rotor shaft bearing etc. with some contact cleaner/degreaser and some good puffs of compressed air. Dry everything off and apply some grease to the bearings etc.
It is also possible that the motor windings are starting to fail.
Pontuação 1
Please check the capester is fully fit or not and maybe the fault is in her capester because nothing that powers the fan
Pontuação 0
Adicionar a sua resposta
sachin gupta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 31
Ao todo: 2,437
