Ir para o conteúdo principal
Guias de reparo e resolução de problemas para notebooks HP Pavilion dv7, fabricados pela Hewlett-Packard a partir de 2008, com tela diagonal de 17,3".
fv 274 av dc jack
I have a dv 7 fv 274 av and think it may be the problem and want to make sure not to get the wrong part . When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out, When I don’t touch it and the light goes on the battery charge but not completely. Somehow the os is now corrupted and I can not get the computer to stay on long enough to do a repair of the system. My thought was a correct replacement of the jack might lead to be able to use the machine again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
murohyg27 this sentence in your description “When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out “ would lead me to changing the DC in jack first. This video should be pretty similar to your system. Of course, you can download the service manual from here
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
murphyg27 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 248
