Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Computer crash then no signal on monitor
This happens to me randomly occurs when im gaming my specs are
GIGABYTE DS3H MOBO
RX580 8GB XFX
GSKILL AEGIS 2x8gb RAM
Ryzen 5 2600
Corsair psu 500w
I also have an SSD and a HDD
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Presumably the screens works again after you restart the computer, is this correct?
Have you checked that the video drivers are up to date?
Have you checked that the case air vents are clear and not clogged which may cause overheating?
Does it only occur with the one game or all games?
por
Adicionar um comentário
1 resposta
The first thing to rule out is overheating (CPU, motherboard, hard drive or power supply), then check for bad memory, also test with another power supply.
Only after checking ALL of these would I think it was a Motherboard issue.
Please do keep me updated. Thank you!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
DjDestroyer27 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,008
